Hello,
I've had a cursory search through some of the forums and can't find the answer I'm looking for - similar, but not quite the same.
Our T6 has factory OPS (as I assume all Highlines do) and has a Westfalia detachable tow hitch.
We bought the van last March and the tow hitch has never been removed. It all functioned as normal until I towed a car on a trailer for a couple of days at the end of January this year. Ever since then, by default, the OPS shows the trailer as connected and deactivates the sensors, unless you press the brake (which obviously triggers a voltage).
Has anybody encountered this before? I don't think VCDS is highlighting anything, but I should probably check again.
