Rear roof lining light loom
MrAPC
Just seeing if anyone has made any plug and play wiring loom for spot lights in the rear, going off the original plugs off the cargo lights?
The catch if you do that is that your spotlights will then be on the general BCM timeout (usually 20 minutes, sometimes 60 minutes, can be coded up to about 120 minutes) that operates on the +12v feed.
Yeah I get that I run the risk of draining the battery, I swear someone use to make a loom that had a switch to flick the lights on as well that but obviously lost the post.
Did you find out anymore on this @MrAPC
Nahhh I decided to just make one myself , plugs were purchased from AliExpress with the pins and just used a crimper
Or failing that just use some superseal plugs from Amazon if you're not bothered about it looking OEM
Cheers buddy. Where did you get your spots from if you don't mind me asking. Just bought a new suede roof liner with spots cut out but no spots.
