Rear Seat Option
BluehawkDan
Hi All,
Has anybody ever come across a double second row seat, that mounts where the existing three seater bench sits. I would like to ideally have two seats off to one side or the other.
Searched online but to no avail. Any suggestions would be much appreciated.
Not using the same mounts but you can get the 2 from a 2+1setup, you’ll need to fit another pair of floor brackets though.
Is this in row 2 or row 3? Row 2 its doable - not sure about row 3.
I’ll check mine out tomorrow and let you know what extra floor brackets needed for row 2.
If you dont have a shuttle or a van that has fat trim panels etc then it will fit just fit on the third row of a LWB. Will see if can find a photo.
Row three sitting a double for fun as someone said it couldnt be done on a FB page......albeit this is LWB so I think on a SWB might be an issue with the wheel arch and the metal pipe of the seat.
ps ignore the millions of brackets as I have total flexibility in my shuttle over four rows........you will just need the two extra ones on the drivers side as the left legs use the existing triple bench left side fixings.
