Rear Wiper Cover Fitting (without wiper)
Kev_
Morning all,
Just put my tailgate panel I and wondering if anyone had fit the wiper motor cover without the wiper? If so how did you fix it? Just the 2 plug and grommets at the bottom? Cheers Kev
Looks tidy that mate! How did you finish the edge of the tailgate when you carpeted it?
Hi Kev
I only did the bottom ledge and cut it inline with the tailgate seal, I did the infil to give the curtains or blinds a neater finish, it’s all reversible if I need a rear wiper fitted later.
Is that the boot release switch? Is that the factory position? I’m in the process of fitting one.
TIA
It’s one off a Ford Focus but fits in the tailgate recess perfectly. At £6 a good mod.
Plenty on EBay
:cool: Thanks mate. I’ve got a VW one here but want to match the OE position!
Yes did that with ours, there are two trim clips as well as a plastic clip that normally attaches to the wiper motor. The trim clips are enough to hold it fine.
Also added the internal factory button.
The switch is 7E5959831 and the bezel is 7E5959527. Not sure on the plug I’m afraid sorry. I got mine from @Pauly as he had one made up with the plug but I’m not sure whether he generally sells them at the mo.
Its terminating them into the crimps for the factory plug
