Reimo rail connector 7mm?
JOT6
I had a Reimo rail fitted and was told it has an 8mm channel. I bought a stitches and steel tarp and it fits in a treat but I wanted to look at a drive away kit, I can’t see anything for 8mm they tend to be 6/7mm does anyone know if the 7mm one would work ok? Any recommend a kit for the stitches and steel tarp specifically ?
cheers
I can’t find a response for the above ⬆️ anywhere & I have more or less the same question. I have a Reimo rail & was told it’s 8mm. Fitting an Olpro awning directly doesn’t seem to work as using just the 6mm beading doesn’t hold (pulls out of the awning rail from the ends) & feeding both bits of beading in at the same time is difficult. Any advice on the best size/type of kit to fit both please so that the fit in the awning rail is snug but not impossible? Cheers.
