Reimo Rail - Vango Galli 2
vw-me
Can anyone recommend a few bits to go with my Awning and Rail ?
I need the connector piece that goes between the awning and the rail and am unsure on which one to get.
Also I don’t want to unpack the Awning until I go away and am wondering how good/bad the pegs are that come with it ? The last thing I want is to be bending pegs.
So possibly need a decent set of pegs, hammer or screw in type ?
The Vango pegs are just (albeit quite decent) wire tent pegs - they, together with the mallet the awnings come with, will be fine in grass but you may struggle on hard standing. Whenever we camp, we have always carried a set of rock pegs together with a normal claw hammer to drive them in and get them out - these now live permanently in the back of the van but, so far, have not been used with the Vango awnings we have.
I like the look of this rascal
(Update—-I’ve just accidentally bought it)
I’ll have to measure my van
Not sure if I need 3m or 4m ?
You'll only need the 3m as the tunnel that connects to the van is less than this. More important is to ensure you get the correct Kador strip bead sizes - they come in 6mm to 6mm and 6mm to 4mm. I connect via a Fiamma wind out awning and use 6mm to 4mm (Fiamma has 4mm channels) but I'm pretty sure your Reimo has a 6mm channel, hence I think you need 6mm to 6mm (NB. I'm not 100% on the Reimo channel size so double check before ordering).
Thanks for this @Davenjo
We bought a set of rock pegs similar to those above, plus a standard claw hammer - work fine on a hardstanding pitch.
Pete
