Reimo Variotech rear shelf
MickT6
Hi All, new to the forum so any help is much appreciated,
Just a quick question about the Reimo Variotech seat, Can you use the rear part as a parcel shelf when driving ? Was hoping to fold the buggy up under it and keep bedding away from the muddy buggy on the back on the seat folding down ?
Thanks in advance!
Mick.
You can indeed…we keep our bedding on it too. With it folded down it also slightly improves the rear view over the top of the seat.
Oh thanks for the reply much appreciate,
We could we our old RIB bed but that wasn’t on rails so didn’t no if the tromp did the same and Google wasn’t any help providing the answer!
Yes, we do this with ours (though not with a buggy)
Can I ask a quick question - does your rear shelf stay up in a ‘locked’ position if needed? Mine used to but now won’t stay up. I suspect I has mis-adjusted a bolt on the right hand side when trying to track down some rattles.
Anyone any idea how to adjust the mechanism which will make it stay up? Reimo instructions are no help sadly.
It stays up on the force of the rams, but not locked in any sense.
Thanks Drinfinity - I’ve been fiddling and fiddling and your comment on rams really helped. I didn’t even see the ram as it was snapped at the eyelet and rotated under the frame. I have a new strut on order and hopefully that’ll sort it!
Ours is always down when driving. We put light things on it when on camping trips.
Same here, our bedding lives on the shelf. We just roll the bedding up in the morning on to the shelf section & put the seat up. Reverse in the evening. It's a 10 second lob to put the bed out/away.
