Remapped t6 loss of boost/power after hitting goat, car perfectly repaired. No fault codes, all systems optimal on diagnostics.
After hitting a goat in Namibia that destroyed the intercooler and temperature censor, the car was repaired. After repairs I keep getting only 1,4 bar instead of 1,7 bar boost between 2000 and 3000 RPM. (the car was remapped using the Quantum Red File). No fault codes at all. All hardware in perfect condition (turbo, injectors). I am out of advice. Please help somebody.
I have now discovered after many diagnostics that there is a voltage drop in the aircon system that influences a lot of systems. Can it be a bad earth? Where do I look?
Welcome, I think the lack of members responses to your original post is likely to be because you've already done all of the things that we'd normally suggest, such as diagnostics. I'm afraid I can't help on the electronics but it would be unusual if a voltage drop in the air con system caused a loss of boost pressure, in my not very expert opinion.
Hopefully somebody with more knowledge in that area will be along soon.
Good luck.
Thank you Dave. I suspect that the lower voltage in the cabin affects some sub-systems, like for instance lower throttle signal to the control unit?
