Removable table leg
MacD
After a little bit of help from people,
I’ve fitted the clips to the door to hold the table to it however the leg is quite bulky combined with the RR bed sitting far back means it won’t shut.
Has anyone seen a removable table leg out there that would solve the issue ?
I have a fold out table leg from Kiravans which I needed as it is adjustable . I leave the leg on the table but it simply unplugs from the mounting screwed to the underside of the table the grey bit at the top of the leg.If that helps.IMG_0193.jpegthe silver feet at the bottom of the leg were added to increase the adjustable range as my van sits a bit higher with the eibach springs, so is more compact than in the photo.
