Loosten bolts 11 right?
Join the VIP club for more great help & Info:
VIP Membership | VW T6 Forum - The Dedicated VW Transporter T6 Forum
Removing and installing assembly carrier:
Window regulator, door lock and loudspeaker are secured to the assembly carrier.
The door lock can be removed only together with the assembly carrier.
Assembly carrier can only be removed when door window is unbolted at window regulator clamping bolts. To do this, lower door window to the height of the assembly holes in assembly carrier and loosen clamping bolts.
If door window cannot be lowered with electric window regulators, first determine the precise cause of the fault.
If an electrical fault exists, rectify it first.
If the electrical fault is due to the window regulator motor, it can be unbolted from the assembly carrier. The door window can be pushed into the necessary working positions by hand.
– Remove front door trim
→General body repairs, interior; Rep. gr.70.
– Remove lock cylinder
→ Chapter.
– Loosen clip -1- from door handle -2-
→ Chapter.
– Lever out sealing plugs -5-.
– Unscrew earth cable connection -6- from beneath window slot seal.
– Lower door window until clamping bolts -11- for door window become accessible.
Note
If work is not possible due to a malfunction caused by electric window regulator, the window regulator motor can be unbolted. The door window can then be pushed into the necessary working position by hand.
– Loosen clamping bolts for door window -11- (do not unscrew completely).
– Press apart clamping jaws.
– Slide door window upwards, and secure it (e.g. with adhesive tape).
– Lever out boot -3-.
– Disconnect connectors -8- and -10-.
– Remove bolts -1-.
– Remove bolts -7- (Qty. 8).
– Pull subframe at top off door, lift it slightly, and swing it out of door towards hinge side together with door lock and locking rod -4-.
– Turn over assembly carrier, and disconnect connector from door lock.
– Pull off clips of electrical wiring on back of subframe.
– Lever out rubber grommet -13-.
– Pull line -12- out of opening -13- and out of rubber grommet -9-.
Installing
Install in reverse order, but note the following:
– Insert assembly carrier in door.
– Start bolts -arrows-.
l Observe bolting sequence on subframe.
– Tighten bolt -1- first, then tighten bolt -2- to specified torque.
– Then, tighten remaining bolts -arrows- in diagonal sequence (no particular order given) to specified torque.
l Then check function with door open.
