Remove webasto from van wiring / leisure battery hook possibly
bullracing
I am starting to look at the possibilities of removing the webasto from the van side of things.
So maybe remove the plumbing so it only goes to the back where I have a heat exchanger. I really do not need it to heat the engine or the cab as I have a night heater and I do not use the van as a daily, its a camper.
I will need to remove it from the wiring if possible OR atleast have it so it runs from my leisure batteries rather then the van battery. I have seperate systems so that the van is no effected by my camping side in any way.
Does anyone have a wiring diagram for the van/webasto side or have any suggestions as to if its possible to run the webasto thermo top from my leisure battery without it effecting anything the van side? I do not want to loose the remote control side of things
