Removing Kombi rear full height bulkhead without access to rear load area.
sparkywig
As title, after being rear-ended and the tailgate being jammed into the frame I need to remove the rear bulkhead to be able to remove all my tools and equipment.
Can anybody show me where the bulkhead fixings are please?
unfortunately the fixings are on the back side of the panel in the load area. I think you will have a seriously hard time to even bash it out if they have attached it using all the fittings
I think you would have more luck getting into the tailgate!
maybe a robust ratchet strap across the bottom corners, with another strap on the pushed in corner and trying pulling it out with the second ratchet attached to an immovable object?
It's sorted, thanks. After removing the rear seats the impact pushed all my equipment into the bulkhead and split it, as it has to be replaced anyway it was cut out.
