From memory there are two small somewhere near where the seat belt enters the black plastic piece on the top of the seat.
also you need to put your hand up the back of the seat where you will find a bolt 17 or 19mm I seem to remember.
This also needs to be removed. There is a large plastic cover other it that needs to be prised off. Once the bolt is undone that allows the seat belt to be pulled through the bottom bench.
Bit vague but all from memory. Not a hard job to do but helps if you have small hands as tight behind the seat covering.
The seat covering has a plastic piece that needs to sorted of rolled towards you to release the fabric.
Hope that helps.
If I can do it anybody can
