Removing swivel base
simont64
T5.1
Hi the drivers seat in my T5.1 has a swivel base never used it was in when we got the van the seat on its lowest setting is still to high so if i remove the swivel does the seat just bolt onto the seat base frame didn't want to take it apart just in case i am missing something it is a rib swivel and it looks like it has a full length spacer under it so i would think that has to come out as part of the swivel
Many Thanks
Simon
In short yes,
Should just be able to unbolt the seat from the swivel (4 bolts) then unbolt the swivel from the base (4 bolts) then bolt the seat directly to the base (4 bolts)
Hi Thanks
Bit the bullet and its done with a struggle all the countersink bolts already rounded off all drilled out sorted and now a seat that works for both of us anybody wants a rib none offset seat swivel needs new bolts name your price collection only heavy or what
Simon
