I would be really grateful for some quick advice please - anybody who has read my posts about electrics will know they're not my strong point. My leisure set up is a Renogy 100Ah Smart Battery (about 17 months old) along with a CTek D250SE DC-DC Charger and Victron Bluesmart 240V Charger. TBH, I tend not to monitor charge levels of the battery too closely as it's usually plugged into the mains at home outlet or EHU when we're away - that said, it rarely exceeds 13.2V when plugged in.
We are in an AirBnB in Greece for a few days and the van is parked up without EHU. I checked the leisure battery late yesterday aftrernoon after it had been supplying the Dometic CRX50 for about 32 hours (and only the fridge). Although I confess that I didn't check the charge state when we arrived, it had just come of the back of 4 hours driving so I'm assuming it should have been good.
As a precaution, we took all the stuff out of the fridge and switched it off as I didn't really want to run the battery down too far BUT I'm wondering whether I've got a real problem or perhaps even the Renogy App readings might be incorrect (or the others). FWIW, the fridge was set at 'Level3' with the removable freezer compartment in place and everything is kept very cold (or frozen in the freezer). The fridge generally behaving as expected with no strange noises! That said, it has been very hot (well into the 30s) so the fridge is probably having to work quite hard.
- The little plug in meter read 13.1V (but it does not give %).
- The BM2 App says 13.13V and 100%. See picture below
- The Renogy BT adapter says 13.2V and 31.87Ah / 31.87%. This is the one that's got me worried! See picture below.
