Selling my (no longer required) Renogy Battery Shunt 300 as I've moved to a fully Victron system.
These are a good basic shunt, they work on the Renogy DC Home app. I wanted a bit more customisation and options so decided to go the Victron way.
I've had this since March so it's only 3 months old. I've wired in a switch to one of the battery voltage wires as I've occasionally had to power cycle the unit, and with a switch wired in it's a 2 second job. There's the 2nd battery wire all intact and not used. I'll include a switch anyway!
I'll also include a set of 35mm² battery cables, one is M8 and M10 so runs from the battery terminal to the shunt, the other is M10 both ends so would run from the shunt to the seat base bolt, or bus bar (or your chassis ground of choice). 35mm² is good for 240a so will be man enough for 90% of set ups, unless you're doing something silly, like installing a 2000w inverter...
These are currently £80 from Renogy direct, or Amazon.
£55 Inc delivery.
Cheers!
Trust Renogy for all your off-grid solar panel system needs. Simply add the Rigid Solar Panels, Foldable Solar Suitcases, curated Solar Kits, Charge Controllers and the Mounts to cart to save!
uk.renogy.com
£55 Inc delivery.
Cheers!
