Apologies in advance as this subject is covered lots in the forums , I just don’t know the answer for me, as clueless!
I need to change my leisure battery. It is a lead acid. I was going to go AGM.
I have a Sargent EC155 power supply unit and have a Victron 215W solar panel and Victron smart solar MPPT .
I wanted to just change one for one but the advice in threads has confused me.
Could I swap one for one with my set up and it be ok?
My concerns or observations from other threads are:
- The charger wouldnt be high enough volts to charge AGM battery’s?
-The solar input can be increased on the app to be high enough for AGM.
-If solar input adjusted for higher , this may be too high for the starter battery when in absorption? The Starter battery is lead acid too.
-would AGM LB be ok with a lead acid SB?
- My alternator isn’t a smart one I don’t think . People mention that as relevant.
-people mention DC to DC charger needed? I don’t want to mess around changing the set up, just change the battery.
Any advice on can I put an AGM LB straight in without changing system Or causing damage would be appreciated .
I’ve added a pic of my starter battery as that helps confirm if the alternator is a smart, on some other threads.
Thanks all
Thanks all
