Replacement front light bulbs.
Texas2981
I have a T6.1 (2020). I want to replace both the dipped beam (the set up is that the bulb is to the left as you look from the front) and the main beam, which is also the daytime running light (the bulb to the right as you look from the front). I want to get the brightest road legal bulbs I can. Has anyone got any recommendations, based on their own experience, suppliers and prices.
Many thanks
Steve.
As @JumpShip says do you have the H4 or H7 headlights?
The H4 units seem to be just inherently a bad design, noticeable by the sheer number of threads about people upgrading them to the H7 units or LED
Jump in to one of the main headlight threads here:
I'd always thought H4 was still a low end option on a 6.1 - every day is a learning opportunity so long as you keep looking :thumbsup:
Its just an assumption that the OP actually has OE factory halogens ....
I think from his description of outer dipped beam and inner combined main beam/drl it would be safe to assume factory halogens.
I wouldn't bother with bulbs if you want a worthwhile upgrade get the transporter hq full led units
