So it seems the previous owner of my van decided to install rear speakers, and instead of inserting new pins into the connector, they completely removed it and passed the cables for ALL of the speakers through the quad lock and directly to the head unit (2018 T6 - Composition colour). Here is a picture of my HU and connector...
I would like to replace the connector in the quad lock if possible and reconnect the speaker cables using the proper pins, for no other reason than to reassure me that everything is hooked up properly and neatly. At some point in the not too distant future I plan to replace this head unit with a better (i.e. Nav & Carplay) one so it will be one less thing to worry about then.
My question is, where can I buy the missing connector block from? Everything I have found so far is the standard ISO one, which I am guessing is different, and maybe won't slot in. It's this one circled here (as seen in one of Pauly's photos, thank you Pauly) that I am after...
Thanks in advance for any guidance.
