So here is my step by step on how I removed the carpet in a 2017 caravelle and replace it with IVC black bamboo vinyl..in the process I also added additional sound deadening, insulation and some cables for 240v and 12v sockets..the job is fairly straight forward but this is not a basic DIY job I think some good level of practical skills are required. All trims have to be removed and you need to make sure the new vinyl thickness will allow the rail trims to click back into place. With the sound deadening and vinyl this was on the verge of being too thick so take this a word of caution if you are thinking of adding in the additional sound proofing (it’s not needed but will help reduce road noise). Also don’t make the same mistake as me and cut the vinyl to the boot profile leave an overhang at this point so you can cut it to shape once it is back in place. Good luck I think it has been well worth it to not worry about sand and mud
