Replacing heated seats with heated Recaro’s
Dev
Hi all, I’m new to the forum. I have a T6 Kombi Highline 2018 which came with factory fitted heated seats with the controller on the dash. I’ve just bought Recaro Ergomed E seats which have the climate pack so are heated. Can I simply wire the Recaro seats to the VW heated seat wiring or is it more complicated than that?
Thanks all.
Not sure how the recaro seats work but VW seats have a 3 wire connection as there’s a temp sensor built into the seat to help control them
Thanks Pauly, my Recaro seats also have 3 wires for the heating. Can I just connect them up then and see what happens or might that do damage to my electrics? Thanks
Its a risk, VW have two fatter cables for power and one smaller cable that is a signal return, its possible yours work the same way but you need to make sure you get the wires the right way around
Wiring diagrams for heated seats are in the downloads section
