[Resolved] no air from passanger vent
Tyrrell
Hi need some help working out where to start with this one. I seem to have a problem with the passangers side air vent nearest the door. you can put the blowers on and all the other vents work but the one nearest the door doesnt do any thing? other than the adjuster wheel on the side of the vent, does it get blocked off any where else? should i start by removing that vent and seeing if the adjuster wheel is opening and closing correctly?
thanks in advance for any help, hopefully someone else has had and solved this problem before!
Shine a torch thought the vent, you should be able to see the vents opening and closing with the adjuster wheel. Other than than it may be the duct has come away from the heater box. Guessing it is not duel climate?
Decided to remove the glove box to have a look at the side of the adjuster wheel as it didn't feel like there was any resistance. Turns out the link arm has come off. Unscrewed the fixing in the middle and removed the vent. The flap was difficult to move so put some silicone spray on it, reattached the link arm, re fitted and every thing works fine now.
Nice easy fix
