Retro fitting hot water
James ATeam van
Good morning all, we have a t6 that is missing one thing! Hot water. Space is at a premium but is there anything we can do with our existing diesel heater (Autoterm) to add hot water to our set up. Thank you!
Given that most converted T6 have a max water capacity of around 70L in fixed tanks it’s likely that you can create enough hot water with a good sized kettle or large pot.
It just takes 20 minutes forward planning.
If you want to heat and store hot water the amount of space consumed is significant. You will also have the safety features to consider such as pressure relief valve, thermostat and Legionnaires prevention.
