Retrofit Air con T5.1?
Iggster
Morning all
I'm just putting a question there I have a 2015 vw t5.1 and I'm wondering is it possible to have air con fitted to the van as its the only thing I'm missing in the two days of summer that we get I live in the Lincolnshire area.
Thanks Ian
Hi. Thread below on this matter.
Anything is possible...
It depends on how deep your pockets are.
If it was £5-8k fitted as a retrofit would you still want it done?
I have just done this, I am very lucky to have a friend who is very good with VAG cars and vans who helped me. I took the full air con system from a donor van. The front end needs to be removed to run wires to under the battery and fit the condenser, pump etc. The dash needs to be removed to swap out the heater box and add in the additional wiring. Holes need to be made in the bulk head for the condensor pipes and drain. It’s a big job and well worth it but as I say, I’m very lucky that I have a knowledgeable friend to help me.
The hardest part is the wiring so if you have access to wiring diagram then the rest is mechanical pretty much.
Rough idea on parts cost?
Or
Labor time or labor cost?
Again I am lucky, my friend does not charge me. I help him where ever I can in return.
I bought the heater box, controls, dash loom, pump, pipes and condenser for £300. I had to buy an additional idle pulley as non aircon vans do not have it and also an auxiliary belt. £60.
£40 to have it gassed.
As this was the first time we did not rush, approx 8 hours.
Wow, a lot less than I was expecting....
Good job that man... Well done.
When I first looked into this I was pricing everything up and the cost was around £700. The donor van was accident damaged and I was able to remove everything myself so this helped me to understand what went where.
Regarding the labour, there was two of us so it’s more 16 hours (2x8) really.
If I knew more about the wiring I would liked to have shared how it was done.
صباح الخير للجميع
أنا فقط أطرح سؤالاً هناك، لدي سيارة فولكس فاجن T5.1 موديل 2015 وأتساءل هل من الممكن تركيب مكيف هواء في الشاحنة لأنها الشيء الوحيد الذي أفتقده في اليومين من الصيف اللذين نعيش فيهما، أعيش في منطقة لينكولنشاير.
شكرا لك إيان
مرحبًا، هل وجدت حلاً لتركيب مكيف الهواء؟ يمكنني المساعدة إذا أردت.
Hi, did you find a solution to install the air conditioner? I can help if you want.
