Retrofit DSG MFSW with paddles...
andy banes
So i now have a full leather flat bottomed MFSW with paddle shift it keeps the std triangle shape air bag cover .
It was supplied and fitted by Paul at retrofit ...Alll i can say is really nice guy, very knowledgable and a cracking product at a really good price!
Can you see it.....
Less than 300 inc vat
Whatever colour and material and thread colour you like
There is a black leather with alcsntara and red stitching still there atm
And you keep your original wheel
All the switches mfsw air bag etc stuff are swapped over
I’ve also discovered that in sport mode a down shift on the paddle is assisted by the lovely boosted match revs for the engine..
It's on my list of mods to do this one... I've seen his site before and wondered how long it would take to do...?
Do you need to spec what colour / material you want a couple of weeks before getting booked in..?
BF24C5C2-F258-4044-AA45-032203848EAC.jpegHi, I’m struggling finding info on adding paddle shift to my 150 dsg. I’ve got vag com so can probably code it but not sure what parts I need. Thanks
Plenty of info here bud :thumbsup:
Can I retrofit these onto my wheel that doesn’t have them? Thanks
Thanks I’m about half way through the thread
I guess it depends how much tweaking/modifying you are prepared to do. I thought someone had done that but can't find it right away.
Anyways, for t6 from the factory there has been 6 different part numbers for steering wheels with DSG paddles, and then another 3 part numbers without the paddles - thus not likely just a plug and play.
Meanwhile some related info also here
I changed my steering wheel to one from a MK6 Golf with paddles and it was plug and play. believe its plug and play on highlines
Can you see it.....
I've just seen this when I looked into it before I was told It wasn't possible.i will be seeking out Paul at retrofit even if he is other end of the country.£300 that's super cheap.
Hi. I have a 2017 t6 sportline in DSG. I was looking to upgrade the steering wheel cosmetically, but I now fancy getting a wheel with the paddles fitted also as mine do not have this as standard. Where do I stand with this? What’s is required, do I just need to find a wheel with the paddles already fitted and plug it in. Is there a specific wheel works best? Thanks
Dan
