gvicker1 Member VIP Member 18 Nov 2023 #1 Does anyone know if you re-use the orginal rubber upper when fitting eibach adjustable son the rear? Thanks Last edited: 18 Nov 2023
Pewt Senior Member VIP Member T6 Guru 18 Nov 2023 #2 No mate.............did the kit come with a small rubber ring that should fit above the adjuster?
gvicker1 Member VIP Member 18 Nov 2023 #3 Pewt said: No mate.............did the kit come with a small rubber ring that should fit above the adjuster? Click to expand... No mate but I bought it second hand. I’m fitting a rubber spacer that I’ve made instead. Like below. It’s only 3mm though Last edited: 18 Nov 2023
gvicker1 Member VIP Member 18 Nov 2023 #5 Pewt said: That's how they go on mate Click to expand... Your a star thank you mate
