Reverse input signal fault
Ryanm218
I have a fault where the reverse light and sensors do not work when reverse gear is selected.
When I monitor parking aid input signal on VCDS the state does not change when I select reverse.
The reverse lights and parking sensors do work when I try them on the output test on VCDS.
After looking at this I ordered a new reverse switch but this is not the fault, the old one was fine when I tested it but fitted the new one anyway.
I have checked the reversing light switch fuse 15 in fuse box SB, that's fine.
Any ideas much appreciated.
Ryan
