I’ve mentioned @Dav-Tec on other threads, but haven’t actually done a proper review, so I thought it was about time.
I first came across @Dav-Tec (Chris) on this forum…. I’d bought myself a custom steering wheel as an upgrade to the crappy plastic thing and needed it coding with VCDS. Chris offered to help with the coding and the fitting of the extra wires (that I knew nothing about at that stage) I needed for the MFSW to work properly on my Trendline T6. Chris is very professional, efficient and particular about his work which is something I liked. He coded everything to work perfectly and also activated the big speedo feature that I couldn’t get before.
Since then I’ve been back to Chris for him to install the Autowatch Ghost 2 Immobiliser as he’s an authorised Installer and TASSA approved. Again, very pleased with his work.
Chris is an Electrical and Automation Engineer by trade and a VAG nut…. to say he is passionate about what he does would be an understatement! He’s got a very trick VW Caddy…. check out that_honey_caddy on Instagram!
So, if you are on Instagram, please take a look at some of his work dav_tec1 as I can highly recommend him. If you’re not on Instagram, maybe he can start his own thread and start to put up what he specialises in….
