Thanks for reading. You'll see if you look at my post history that I've had various electrical issues since new. Latest one is baffling me. Revolution have gone bust, so have no way of getting wiring diagrams or advice from them direct.
The leisure battery (under the driver seat) is fully charged and tested.
There is no power going to the leisure equipment from the battery (i.e. fridge, lights etc.)
There is no recharge power reaching the battery from the running engine. Main engine starter battery is recharging perfectly.
There is no recharge power reaching the battery from the 240v mains when the van plugged into the house supply. (240v is working and all leisure systems working (apart form battery charging), when connected to 240v supply.
Any advise would be really helpful.
I attached some photos of the wiring and modules attached to the leisure battery. Could someone also help me identify what these are? Thank you so much.
There are two red cables going to the positive batt. terminal. The empty fuse here, does have a blue fuse installed. I removed it to check the contacts. made no difference when i puched the fuse back in,
What is the VW AG box. The yellow fuse also has a black fuse behind it, both fuses seems Ok to me,
