RIB Bed installation with Altair Anchorage kit
daytonamick
Hi there ... I bought a 112cm RIB bed from Miriad ( the cheapest I could find) however it is not specifically for a T6 and I'm worried that the frame fixing points are not compatible.
I have installed the Altair Anchorage kit between the chassis beams and this has provided a good fixing for the rear of the bed using the 2 x pre-drilled fixing points (I could also drill the bed frame to get more bolts into this Anchorage beam). The only other fixing I can get is the right hand side mid point which pops through under the exhaust heat shield ... however I can not get a fixing for any other of the pre-drilled positions at the front of the bed.
Has anyone else had the same issue ?
Thanks Mick
I have removed the spare completely to install the the Anchorage beam but the front fixings are all inaccessible (exhaust, suspension struts etc). I wonder whether the fixing to the beam and possibly another 2 fixings in the mid section will be adequate
