It something I wanted to do from day one but got talked out if it at the time.We have a sliding RIB which uses two caravelle rails. I think you would need a new thicker floor to accommodate rails which may impact on your other units so not a small job. There are a few converters who offer them so may be worth a phonecall.
I wish I had done the same as like everything to do it afterwards will cost more. ThanksYes it is really practical and we use the feature all the time. Like you we were initially talked out of it and the cost was a bit eye watering but we came back to it and stood firm, it was well worth it for the flexibility. Hope you find a solution.
I sometimes wish I could go back to the beginning and start again but I guess I would still miss a lot of thing and still left wondering.Nah. I'd guess it's easier to move with 4 rails as it would be less likely to twist which could jam it up. Smoother slide.
I wish I'd pushed harder for this as it is a great 'nice to have' but to be honest it's a minor miss.
The more I’m looking into it the cost it just to high. It’s a job that has to be done at the point of conversation really.i would suggest either.... taking less stuff or going and buying a nice brenderup camping trailer ang having a removable towbar fitted.
ghe rib flux is a good system but you are looking at a rail install, new floor and new rib (flux) bed, possibly upholsty, caravelle step plus threshold..... Im guessing there will be little change from 7k. remember this is to solve a problem when you are on your way camping. How many hours a year does this problem occur? is the solution worth the spend or is there a cheaper way of solving the issue?
Towbar mounted bike rack with a box/platform maybe? Would need to check the available height below your existing bike rack.The more I’m looking into it the cost it just to high. It’s a job that has to be done at the point of conversation really.
I have a detachable tow bar fitted already and the bikes go on the T6 bike rack. It’s the awning and inflatable kayak if I can get a sort of flat surface to attach to the tow bare I could put them on there below the bike rack and that would make a lot more room.
I have the genuine T6 one on the tailgate plenty of room. Just had a ideal I have this in my garage from my old camper. I could make a shelf/box and bolt it onto the this bike rack that is a tow bar mounted one.Towbar mounted bike rack with a box/platform maybe? Would need to check the available height below your existing bike rack.
