Right head light & left main beam out
Cliffecc
Help please, had 12 v socket fuse blow last week, just noticed right head light and left main beam are out.
Is it likely to be fuse related and if so which one
Thx
Cliff
More likely to be the lamps gone, but worth checking fuses.
Check the 2 pink 30A fuses.
Cheers will check that, put new bulb in and still no joy.
Lower 12v socket is working but the on top of dash isn't, dealer not much help, he thought they were on same fuse
No, the top dash fuse can be in one of 4 locations, do you have a second battery?,
1.
2.
3.
4. under passenger seat
@Loz lights seem to be good Now
Just seen an old post from 2017 where you have said the top 12v is a blue block 20A fuse.
Is that likely to be the case on my 2019 van?
did you look at the photos I posted ?
those are the locations check if you have a fuse in those locations and if it’s blown.
Yep, no fuse in pictures 1-3-4, the pink block fuse felt loose so removed and replaced, lights now working.
No fuse at pic 2 slot 40
