Follis
I originally installed a flexible 100W panel on the roof some years ago which lasted about 3 yrs before failing... upgraded the whole system with a german 160W flexible panel feeding into a CTEK DS250SE controller charging a Leisure AGM battery... all has worked fine from 2018 until now (2 weeks before we go on holiday!)
Having measured the 0.2V output from the panel, it appears it has failed...
I'm looking to fit around the same output rigid panel onto the roof and would prefer to mount it via a rail system thats bolted... my dad had the Sikaflex adhered corner mount system on his VW which was unintentionally lost going over the bridge into Wales which is why I don't fancy that option.
My question is have any of you used a nice roof bar / rail system on the pop top that works well with rigid panels?
