Road noise or not
Ratsorhys
Faint whump whump sound on front off side, sounds a bit like a flat tyre noise. Tyres good and correctly inflated, the sound doesn’t get louder the faster I go and no change on bends or roundabouts. If I put in neutral and open the window and free wheel the noise is the same .
Is it just rd noise
Something in the tread, or a deformity of the tread ?
Have you removed the tyres and checked them all over ?
Pete
I would remove each one and check the tread and side walls thoroughly.
As mentioned, if the noise persists then swap front and rear to see if it makes a difference.
Pete
Bearings should last longer than that - as posts above said, swapping wheels over to see if noise goes with sounds like a good suggestion - could easily be a tyre Issue.
