M MrAPC Member VIP Member 16 Apr 2024 #1 Have these ply trim pieces for the roof lining, what's the best option with regards to clips, ideally after something that is hidden if available. Any help is much appreciated.
Tim Sparkes Senior Member T6 Pro 16 Apr 2024 #2 Is your roof lining the same size as the original? If it is your best bet is to trim the original strips and use these.... 20 x LONGER VW ROOF TRIM CLIPS When lining the interior of a VW Transporter you may find the standard clips can no longer secure the panel to the van due to the extra thickness www.harrisonstrimsupplies.co.uk
M MrAPC Member VIP Member 16 Apr 2024 #3 Tim Sparkes said: Is your roof lining the same size as the original? If it is your best bet is to trim the original strips and use these.... 20 x LONGER VW ROOF TRIM CLIPS When lining the interior of a VW Transporter you may find the standard clips can no longer secure the panel to the van due to the extra thickness www.harrisonstrimsupplies.co.uk Click to expand... Sadly I don't have the original pieces as they were damaged when the van was a working van
