Thats what i was thinking, i presume i need to very carefully scrape off the rust 1st? Can i then use the touch up paint once the rust has been taken offIt looks like the door was opened up against a wall or something.
Touch it up with a touch up paint, or have it painted professionally. They are your only real options.
Nice 1, i'll give that a go this weekend if i can get the white touch up paint in time.Just scuff away the rusty edge with scotchbrite then drip touch up paint down the door edge.
Other skilled option is to soft edge the main door face and back of the door and then do a paint repair on the edge leaving only a minor visible line.
I'll check that, cheers. I'm starting to think the wife may have done it opening the door and not said anythingBefore you touch it up just check it could't have been caused by closing the sliding door. I have a very similar looking chip in exactly the same place which is definitely due to my sliding door making contact on a heavy close. Looks like you also have some scratches around that from contact with something else too though.
