Sagging Roof Panel
Littleblackflash
Auto Engineer
VCDS User
The previous owner of my van had a bulkhead in it which has now been removed. The middle roof panel which is directly behind where the bulkhead was is starting to sag at the front.
Should this now be replaced with a longer panel or is there a wider strip panel to hold them up.
If you get in touch with a few local converters they might have the longer version from a converted van without bulkhead. The usually will give them away as they normally go in the bin.
