Hi, I have a 2017 VW T6 Euro 6 with CTEK 250SA and Sargent EC155. All was fine until I connected the Solar panel cables. After connecting the panel the Sargent still worked fine, but when I turned on the ignition (With the Sargent on) the Sargent control pad started to beep, had 3 red led's showing, made a bit of a crackle noise and then died. All fuses checked and ok. I'm getting 12v from Leisure and Van battery outputs checking on Sargent plug connections 5 and 8, and continuity on earth 2 & 3. Tried different CAT5 cable, have disconnected all cables on Sargent and reconnected, still dead. Any ideas anyone before I call Sargent on Monday? TIA, Rik.
