Satnav
Olly T6
blackberry 240 DSG
anyone had problems with there satnav on the t6? I keep putting post codes in but it never finds the address, is this just how they are?
No problems at all - you are putting the postcode in the correct section?
Mine works fine, although its a pain putting in the postcode, it always finds the right address.
To input postcode you have to go to address entry screen then tap on city then tap on the little postcode (abbreviated) box in the bottom left corner
On the older software you have to get the space in the right place, if you are on the newer software (or update) no space is required
