Seat Airbag Wiring - Soldering Looms - Resistance
bullracing
I have installed a set of T5 captains in my T6.
The seats have side airbags but the connectors were different. I have the connectors from both a T5 and T6 with cables on.
Can I make a loom for the airbags by soldering the cables together or will this change the resistance of the wire and make the airbag light come on? Or should I just put a resistor in place. I assume bth the t5 and t6 airbags run on the same resistance so should be ok in that respect..... I assume.
Can I just confirm that there is a negative/earth on the outside on both connectors and the middle and other side is the airbag? They are slightly different colours but there seems to always be an earth on the outside (brown wire).
