Hi,
Could someone please post a picture of their driver’s seatbelt anchor mount please? The end with the splined bolt at the base of the B pillar....
The reason I ask is that mine was mounted so it points up, and the seatbelt has half a turn on it and doesn’t lay flat, so I removed it, and there’s marks on the paint that indicate that it should point up, but then the seatbelt doesn’t sit correctly. If I turn it around so the seatbelt lays flat, it points out towards the centre of the van.
Which is correct!?
Ps I didn’t do the conversion!
Which is correct!?
