Electrician
Hi.
I opted for the factory fit second aux battery under the passenger seat in my 2024 T6.1 van.
I fitted an inverter from it for charging laptop and power tools, and occasionally use it for larger loads such as drills and breakers, or even a kettle.
It has worked great for almost 12 months.
Recently the inverter now alarms and shows battery low at 12.2v ish, and I’ve seen it drop to 11v. I’ve checked charging voltage at 13.8v with engine running, so it is meant to be charging.
I’m assuming because the battery isn’t being used to a great extent, it’s died?
Wondering if there’s a better type of battery to use than the lead acid there?
Spoke to one chap and he’s said to try charging the battery with a charger to give it life, but isn’t that just the same as what the alternator is doing daily?
Any advice would be great!! I’m an electrician, but batteries and the best option isn’t my line.
Thanks.
Thanks.
