I've searched hi and low and read the whole of the internet that doesn't have the answer, so how do I go about finding the VCDS security access code that gets me into the secret depths of the central electrics?
When you hover the mouse over the security access field the VCDS shows the code - if one is known. However, the T6 central electrics doesn't have/need one
Codes currently known for the BCM just allow access to read eeprom & update with Odis/VCP etc
I’ve gone through every single possible code with VCP and those are the only 2 that are accepted
lol another year another air filter code - removed and cleaned the ramair panel and oiled but change air filter light on dash. I no longer have obd11 pro, any other options? Seems silly paying a £50 sub to reset the air cleaner light!
Should add it’s in for its annual oil change end of next week, so I could ask them if they’d be willing to reset it (depends if they will seeing as they aren’t changing the filter). If they want to charge me extra for resetting that or refuse then not sure.
