service schedule 4th year schedule
i moved over to 12month / 10k miles - oil + filter
other service items as required.
official word:
Full service - £295+vat (oil/filter/Health check/as per service schedule) (Price increase 2022 - £335+vat)
Full Service
We'll make sure to check the:
  • Lights
  • Horn
  • Instruments
  • Washers and wipers and top-up fluid
  • Tyre condition and tread depths
  • Tyre pressures and correct them if needed
  • Airbags for visible damage
  • Sunroof
  • Tipper system and change the oil if necessary
  • Paint and bodywork for damage and corrosion
  • Expiry date on breakdown set
  • Engine and engine compartment for leaks
  • Condition of visible drive belts
  • Gearbox, final drive and rear axle for leaks and damage
  • Manual gearbox oil level
  • Final drive oil level
  • Brake system for leaks and damage
  • Thickness of the front and rear brake pads/linings
  • ABS sensor and cables
  • Underbody sealant and panels for damage
  • Supplementary rubber rings
  • Condition of the exhaust system
  • Steering joints and boot for wear and damage
  • Coolant levels and anti-freeze strength
  • Condition of the camshaft drive toothed belt
  • Power-assisted steering oil level
  • Brake fluid level and condition
  • ATF level (automatic)
  • Battery
  • Idle speed
  • Adjustment of headlights
  • Drive shaft
And we'll also:
  • Run a vehicle systems test and read fault memories
  • Grease the front door check-strap and hinges
  • Grease the trailer coupling
  • Change the engine oil and filter
  • Change the gearbox oil if necessary
  • Change rear axle oil if necessary
  • Renew the air filter
  • Renew the pollen filter
  • Renew the fuel filter
  • Perform engine basic settings
  • Perform a road test
