Show us your table top.
Me too @andys. Got the table swivel post. The wife will spend hours picking a table cover from pixers.
Still she is happy so I am. :thumbsup: ;)
Hi @Calps82, would you mind telling me the dimensions of your table? Looks like a good setup and I think I read in another post that you used a lagun swing arm? How do you find it?
The table is superb and works well between our seats when the fronts are swivelled and also as a table at the back of the van when cooking etc under the tailgate. chippys can make you a table to your own dimensions, I made a template and messed with it until I was happy with as big a table I could get away with so it still swivels from inside to outside without jamming against the rear seat if you know what I mean. It’s 850mm x 450mm.
The lagun leg is great but you need to use the supplied wooden board just to bring the mount away from the van bodywork a little so there’s enough space to spin the table leg without it fouling.
Thanks @Calps82, great info and that's a good point about the clearance to be able to swivel from inside to outside and vice versa. Think that's made my mind up and I'll go down the same route.
