1 1975T Member 15 Apr 2022 #1 Evening All, I need to remove the plastic trim on my shuttle as per the photo to mount a bracket for a small table. What’s the best way to do it?
L Linoleum Bonypart Senior Member VIP Member T6 Guru 15 Apr 2022 #2 Interested in this as I have said table too ….are you going to reinforce the trim
Skyliner33 Senior Member VCDS User VIP Member T6 Legend 15 Apr 2022 #3 It looks the same as a normal van. If so: sear belt bolts out. pull the top panel off pull the lower panel off.
1 1975T Member 15 Apr 2022 #4 Thanks Skyliner33, it sounds straight forward enough. And yes Linoleum, I am going to reinforce behind the trim.
L Linoleum Bonypart Senior Member VIP Member T6 Guru 18 Apr 2022 #5 Swing Out Table How to www.vwt4forum.co.uk
M miguel 32 Member VIP Member T6 Pro 25 Apr 2022 #6 Hi What size are the T splines that hold the seat belts in place?
