Any ideas rear display not working so no heating in back i have check the fuses under the gear stick I have pressed the rear button on main heater took display out and no wires broken thanks san
Took display moved plug in and out it lights up and starts the heater then goes black again
If I put my meter only in the red wire and the other lead to earth I get 12volts if I only put my meter on brown wire and other to earth I get no reading on meter . if meter in red and brown same time I get 12volts
Don't know if this has any to do with the fault When I press the rear button ( in front cab) it only stay on few a few seconds also thanks for the help
Hi I think it is the unit cos I have check all wires for dodgy connection/ broken wires. Next im going to open the unit up and check for day joints is it the same as this one and how much you looking for it
Don't want out for it it came with a shuttle interior I bought to use some bits from no use in mine it's still in roof lining so need to remove PM me your address I will try to get in post tomorrow
