Graham McD
Hi, Can anyone help please, I have no side or cab lights. I have replaced fuse as it was blown, and disconnected and reconnected the battery, as advised. Still have no lights on either, any help would be appreciated.
It’s a trendline, was changing interior bulbs for led’s, took out the light unit wrong, and it blew the fuse. Think it might need plugged in to fix.What spec van?
have you re-checked the new fuse?
any idea why it blew?
VW T6 Fusebox Listings & Electrical Info | VW T6 Forum - The Dedicated VW Transporter T6 Forum
Fuse Card
VW T6 Fusebox - Fusebox/Fuse Chart SC - Lower Dash Fusebox Listings
VIP Membership | VW T6 Forum - The Dedicated VW Transporter T6 Forum
Have you checked the fuse with a test-light or multi-meter for 12v power feed at both sides of the fuse?
you mave have blown one of the cartridge fuses at the bottom.
what fuse blew? - SC20? (3rd one down top left?)
best thing to do is check all the electrics to see what if anything else is not working,
then go from there.
Cycle the ignition?? It is definitely that fuseOh, and cycle the ignition too.
Yes this is correct, after changing the fuse you need to cycle the ignition which, I think, resets the computer.Cycle the ignition?? It is definitely that fuse
@t6 steve I had the exact same issue after a certain poptop roof installer disabled my van by pulling out a specific fuse. All of those circuits are controlled by a 7.5a mini blade fuse in location SC32. Go to my thread Hilo Sport Roof Reviewhi , iv got a ploblem if you can show any light for me please iv got no ignition lights at all wen I turn the key its a 18 transporter first of all my interior lights went off as I took down roof lineing but I left it I thought just a fuse do it another day then I noticed I ad no rear lights so few days ago I decided to check the fuses out I droped the one fuse loseing it down behind the trim so don't know if it ad blown or even the right fuse I took out I went on here to find were it was , iv took about 4 fuses out to check them and looked ok so I left it for couple hours then on eveing went out to park it up for the night and would not turn over and iv noticed iv got no dashboard lights at all no ellec windows no fan no headlights no interior lights only thing I found working is the radio and the hazard lights gone back over most the fuses even checked the fuses by the battery .iv checked the battery itself seems plenty of life in there cant see it being that.so im bit at a lose end iv only got one key was wondering if iv taken a fuse out that now as disabled the transponder /immobiliser system .iv just read your coments above about resetting the computer. so if you could help me in anyway it would be appreciated before I have to call out a auto electrician wich trying not to do,and im sorry to bother you, thanks steve
