Hello, after some help. See a lot of different water pumps and ways to set them up. I’m after a simple system including the water pump only not including the accumulator.
Apparently the Shurflo 12v 30 PSI is good, what other equipment will I need?
A simple system is a micro switched tap with a submersible pump, there is no need for an accumulator with this set up.
Have a search on the forum, a positive displacement pump with a pressurised system / accumulator has caused problems and is unnecessary.
