Graveydogg
Hi All. A few weeks back I had the roller on the sliding door fail / disintegrate through corrosion. Although this was only a 5 year old van, it seemed a common problem. Through searching the forum I also discovered another common problem - sliding track channel water collection. This was something I’d increasingly noticed over the three years we’ve owned our van. Looking at where the water was coming from I then realised that the outer door bottom seal was not only blocking the door’s inner drainage holes and also trapping water draining around the door into the channel. Last week I took the bold [and hopefully not foolish ] measure of cutting the bottom section of this seal at the corners and removing the bottom section and f seal. This now seems to be allowing water to drain out effectively- exactly like the cab door arrangement where the seal is discontinuous at the bottom. Is this a widespread design flaw?
